Forums/Z31P/z31-repairs-forums engine-mechanical/Screws that go into the plenum?
Imported from Z31Performance.com Forums{{#if:Hikari86| — original post by Hikari86}}{{#if:2019-02-26 17:26:47|, posted 2019-02-26 17:26:47}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/542558-screws-that-go-into-the-plenum.html|
Hikari86: (2019-02-26 17:26:47)
This has been an impossible find for me. The plate that has "300zx" on top of it has 6 screws that attach it to the plenum. i have an air leak and im missing 2 of those screws, when i was trying to diagnose why my Z isnt really moving, my buddy recommended to test to see if the leak was coming out from where those screws are supposed to be. I put break clean in them to test and you could hear a major difference for a second. Leading me to believe that i should REALLY find those screws that keep the top plate on the plenum. The only problem is my vocabulary is limited as i've only been a Z31 owner for just about 2 months. I do have previous mechanic experience but this is different from Honda by a mile. Could anyone help guide me in the right direction?
zachary.ard: (2019-02-26 17:29:27)
Should be m6 flat head cap screws. 12mm long
8631z: (2019-02-26 18:25:47)
i don't think those screws go into the air cavity. did you get brake cleaner into the bigger holes down the center?
Z_Karma: (2019-02-26 19:01:41)
{{#if:zachary.ard|zachary.ard wrote:|Quote:}}
Yep, easily available at any local ACE hardware. They are blind holes and do not pass through to the plenum chamber though.
jdmlegends: (2019-02-28 01:32:58)
Come to think of it, what's the best way to remove stubborn plenum screws without damaging them? I wanted to polish up my plenum cover, but the screws are a pita to get off even with liquid wrench. They won't budge and I don't want to strip the grooves on the Philips head.
Z_Karma: (2019-02-28 02:23:24)
Use a manual impact driver like this and this is the important bit…a #3 Phillips driver bit. A #2 Phillips is too small and often strips a stuck #3 fastener.
You seat the appropriate bit into the stuck fastener and whack the back of the impact driver with a hammer, the driver bit twists counter-clockwise with the impact of the hammer and shocks the screw loose.
drewcole5150: (2019-03-18 21:45:08)
300zxpartsforyou.com I have found some small minor parts like this here. Hope it helps your search.
