Forums/Z31P/z31-repairs-forums engine-mechanical/Rich exhaust smell
Imported from Z31Performance.com Forums{{#if:GTree| — original post by GTree}}{{#if:2019-11-05 02:52:26|, posted 2019-11-05 02:52:26}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/544710-rich-exhaust-smell.html|
GTree: (2019-11-05 02:52:26)
I recently got my 86 turbo running pretty smooth. Only problem or what I think is a problem is the somewhat rich fuel smell coming from the exhaust. There is a slight hazy white smoke but it doesn't seem to be there all the time. I only smell the fuel when standing towards the back of the car, can't really smell it in the engine bay. Anyone know where I should start looking or if the fuel smell is just normal for these cars or older cars in general? Maybe a stuck open injector? I'll check tomorrow to see if any of the injectors aren't opening correctly.
GTree: (2019-11-05 03:27:06)
Additions to the post that might pertain to this:
I am not completely sure if the exhaust system is all stock. Doesn't seem like it from the muffler anyways and I am not sure if it has a cat, I will check to see if there is one down there. If there isn't, would that produce a fuel smell out the exhaust?
I also have not checked the FPR to see if the top vacuum line smells of gas, will try to do that tomorrow.
Another thing I should note is that the exhaust tip seems to be covered in a black or "sut" substance. It's been like this since I've got the car. While it is running or if I rev it up the car doesn't seem to really blow out any sort of smoke other than the hazy white smoke as mentioned above.
