Forums/Z31P/z31-repairs-forums engine-mechanical/Heater core leak
Imported from Z31Performance.com Forums{{#if:Gem84Znt| — original post by Gem84Znt}}{{#if:2021-02-02 12:52:00|, posted 2021-02-02 12:52:00}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/545785-heater-core-leak.html|
Gem84Znt: (2021-02-02 12:52:00)
I have a small leak at my heater core. Can i just disconnect and plug just the intake coolant side without causeing a problem?
Z_Karma: (2021-02-02 18:17:45)
Just get a section of hose and jumper the supply and return together where they come off the motor and pass through the firewall.
You'll likely have to remove the heater control valve to access it, but once you jumper the two ends together it's kinda pointless to have it anyway.
