Forums/Z31P/z31-repairs-forums engine-mechanical/Extreme Smoking
Imported from Z31Performance.com Forums{{#if:klasens| — original post by klasens}}{{#if:2024-03-21 18:49:53|, posted 2024-03-21 18:49:53}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/546699-extreme-smoking.html|
klasens: (2024-03-21 18:49:53)
Hi Guys,
I bought a second z31 turbo. However, it keeps smoking and stinking at an extreme rate. I already changed the turbo for another one from a scrapped car. Do you guys have any idea what is likely the issue ?
Z_Karma: (2024-03-22 16:14:57)
What does it smell like?
What do the plugs look like?
Coolant = sweet smell
Gas = fuel/petrol, obviously
Burning oil = burning oil (leakdown test to determine where the oil is leaking)
mwolvinm: (2024-03-24 16:52:39)
You can pull the plugs and inspect them too.
RoyalZ: (2024-04-01 22:43:59)
one way to see to check also is undo your oil cap on the valve cover and see if smoke comes out of there during idle.
tcfs: (2024-04-08 00:16:15)
Definitely need more information from the poster....
