Forums/Z31P/z31-repairs-forums engine-mechanical/Exhaust smells of heavy gas.....
Imported from Z31Performance.com Forums{{#if:Spazzymcgee| — original post by Spazzymcgee}}{{#if:2019-01-13 18:56:46|, posted 2019-01-13 18:56:46}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/542113-exhaust-smells-of-heavy-gas.html|
Spazzymcgee: (2019-01-13 18:56:46)
Sooooo can not seem to figure this situation out for the life of me.. Got new rack&pinion put in and when I go to start up I get the usual normal startup but a HEAVY smell of fuel out the back....
Any thoughts?
JSM: (2019-01-14 01:01:28)
Doubtfully related.
Spazzymcgee: (2019-01-14 01:40:08)
Well yes I know this but ideally what would cause this smell to randomly just start. I've never had this happen on any of my other Zeds.
Z_Karma: (2019-01-14 02:24:36)
Two thing off the top of my head:
Leaking FPR: A failed diaphragm can cause this. Pull the vac hose from the top of it and see if it smells like raw fuel.If it does, replace the FPR.
Leaking injector: Inspect the sparkplugs and see if one of them are wetter than the others with raw fuel.
Or install new plugs and take a drive for a few miles then pull them and see which one fouls first.
The FSM has a injector test procedure too,
My 84T has a leaky fpr that I've been neglecting replacing until the weather warms up.
JSM: (2019-01-17 03:51:28)
Failed CHTS too if it’s just exhaust fumes your smellling
drnict61: (2019-01-23 18:59:37)
A faulty or missing O2 sensor will cause an excessive rich condition, too
Dunkine: (2019-01-30 01:17:37)
Did you check the ecu for codes?
