Forums/Z31P/z31-repairs-forums engine-mechanical/Custom upper intake manifold?
Imported from Z31Performance.com Forums{{#if:300zxt| — original post by 300zxt}}{{#if:2016-10-02 02:04:36|, posted 2016-10-02 02:04:36}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/532590-custom-upper-intake-manifold.html|
300zxt: (2016-10-02 02:04:36)
AaIt's been a while since I've looked around on here so before I engage my local fabricator, is anyone still doing the custom plenums? Particularly the tapered log style.
Sorry if in wrong section, using mobile device
darryl rice: (2016-10-02 02:52:16)
That looks great. What size throttle body is that? What kind of price are you looking to sell the plenum for?
darryl rice: (2016-10-02 02:59:59)
What size shot of NOS are you shooting? Your set up looks great. What is the estimated hp level you have and capable of.
88sinZ: (2016-10-02 07:19:17)
Are you asking if anyone builds them?
It's easy enough to prep your own using a intercooler end tank granted you have the tooling, i built one for $4XX USD https://z31performance.com/forum/z31…mad-max-intake
LMK if you have any questions
300zxt: (2016-10-02 08:00:37)
It isn't mine. I'm looking to buy one like that, not sell one! Lol
300zxt: (2016-10-02 08:02:22)
I don't mind that but need to be able to shut the hood without cutting.
88sinZ: (2016-10-03 02:19:17)
is it due to need or want?
There's not much clearance to lower the engine, so you'd have to considered using oval piping or trapezoid style - adding to the complexity of a tapered design.
From the lower flange surface to highest point of forward elbow is maybe 4.5-4.75", hood skeleton will limit by another 0.5" or so. it's a tight fit if you want a fwd facing intake.
300zxt: (2016-10-03 09:28:27)
Yeah I think you've done a good job fitting that. The factory gutted plenum will probably meet my needs but I'm just aiming to shorten the piping and get rid of that elbow.
I just recall SATAN used to fabricate these, unsure if they cleared the hood however. Ideally the one pictured above however looks to be a bit narrowly tapered towards the rear cylinders.
mtherkamp: (2016-10-03 13:20:32)
I made my own, not terribly pretty, but can be done with no more tools than a piece of aluminum plate and a welder, click the link below to my build thread and it will show you what I did…
