Forums/Z31P/z31-repairs-forums engine-mechanical/Cllutch hose replacement
Imported from Z31Performance.com Forums{{#if:MikeV| — original post by MikeV}}{{#if:2016-01-06 23:21:26|, posted 2016-01-06 23:21:26}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/25529-cllutch-hose-replacement.html|
MikeV: (2016-01-06 23:21:26)
Hey folks,
My 1987 n/a 300zx needs a new clutch hose. Nissan just informed me that the part I need is discontinued. This is the hose that runs from the master cylinder to the dampener. However, I do not want the dampener anymore. Is there a site that sells a hose that runs from the master cylinder directly to the slave? I found one on this forum not too long ago that I thought may work, but it turned out to be a hose that ran to the dampener.
There is a place in town that makes hoses, which I have already gone to. They made a hose with too big of an adapter on the master side… I live in a small town, so things like this are sort of hard to come by.. Our junkyard has no relevant cars in it either.
Could anyone advise?
Thanks,
Mike V
Twotone200488: (2016-01-19 14:42:27)
A front brake line from a 280zx will bypass the dampener.
Tempast: (2016-01-20 04:00:24)
You need a whole new line, not just the clutch line to damper. I used this when I did my auto2manual swap.
http://www.enjukuracing.com/products…0sx-89-98.html
Axel kain: (2016-01-27 15:20:16)
yeah, if it's the hardline that's at fault, you can either make another from brake line (pipe) or get the adapter line posted above. when I did my last auto/manual swap that's what I used, fits well, and does the job!
