Forums/Z31P/z31-repairs-forums engine-mechanical/Bronze or Cast Iron Valve Guides?
Imported from Z31Performance.com Forums{{#if:tcfs| — original post by tcfs}}{{#if:2021-04-12 03:12:41|, posted 2021-04-12 03:12:41}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/545911-bronze-or-cast-iron-valve-guides.html|
tcfs: (2021-04-12 03:12:41)
It has been awhile since I have posted or even checked Z31p, but I was hoping to get some advice or opinions on an issue.
So, I have some heads that I am working on that have some cracked valve guides. Should I go with bronze or cast iron? The heads are going on a turbo build with some mild performance. End goal is to land somewhere between 300 and 400 hp.
What do you all think? Steel valves with bronze or cast iron guides?
