Forums/Z31P/z31-repairs-forums engine-mechanical/Alternator top bolt snapped inside housing.
Imported from Z31Performance.com Forums{{#if:SynthwaveIntensifies| — original post by SynthwaveIntensifies}}{{#if:2019-07-11 16:51:26|, posted 2019-07-11 16:51:26}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/543838-alternator-top-bolt-snapped-inside-housing.html|
SynthwaveIntensifies: (2019-07-11 16:51:26)
For what ever reason the top bolt that hangs the alternator on the block snapped apart and left a long piece inside the housing causing the bracket to swing into the crank pulley and grind into it. I was wondering if its possible to drill it out or something without pulling the engine out or if there's a better way to do it? Thanks and sorry if this doesn't belong here.
