Forums/Z31P/z31-repairs-forums engine-mechanical/1984 Datsun Nissan zx turbo piston damage
Imported from Z31Performance.com Forums{{#if:ETz31| — original post by ETz31}}{{#if:2018-10-22 04:18:39|, posted 2018-10-22 04:18:39}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/541459-1984-datsun-nissan-zx-turbo-piston-damage.html|
ETz31: (2018-10-22 04:18:39)
Got the car off a friend for $150 it ran and drove before I pulled the engine and trans to freshen up. Pulled the heads and 2 cylinders on passenger side have damage around the lip. We're can I get oem grade Pistons with out having to pay a arm and a leg from Nissan. And does anyone know what caused this. A lean issue?
bonfire79: (2018-10-22 07:50:30)
possible detonation i would think. you can get stock piston kits for a fairly good price if you look around. i got a set from rockauto.com for my NA, slighty bigger but to OEM specs. can't remember the brand. the kit was around 150 bucks maybe a bit more. they have been working great.
Bon
Dunkine: (2018-10-22 20:42:10)
Might not be able to get them from the dealer anymore. Nissanpartsdeal is showing turbo piston with pin for $66.77, but with the Limited Availability caveat.
If you are just trying to build a cheap daily driver or fun car you could try to get a pair used. Another option would be to swap in an NA bottom end or even a complete NA engine for a little more compression.
ETz31: (2018-10-23 15:30:51)
I thought the wrist pins on the z32 Pistons are bigger is that not the case?
ETz31: (2018-10-24 13:50:53)
I will thanks
