Forums/Z31P/z31-repairs-forums electronics/mice meet wire
Imported from Z31Performance.com Forums{{#if:masterewok| — original post by masterewok}}{{#if:2014-10-14 19:48:30|, posted 2014-10-14 19:48:30}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/24406-mice-meet-wire.html|
masterewok: (2014-10-14 19:48:30)
i planed to tape off what mice chewed up.
bad idea?
sure its a headache to replace all wiring.
most leads to anti theft cell, which i was going to disconnect.
is it possible to disconnect/cut wires before where mice nibbled?
the rest go to conections where my center console sits next to my e brake.
what is their function?
forgive my ignorance.
i live on the farm now and only have my phone to seach threads.
thanks for your help.
FlyingT: (2014-10-14 20:03:14)
Please fill out your profile and give you car year and type. You would get more responses if you do.
Solder and use heat shrink to re-connect the wires. Then wrap them in black electrical tape.
visco1: (2014-10-17 23:07:55)
I had 3 cars get the mice treatment and then I declared war. What a pita. took months to figure out the issues then fix them and then finally nuke the rodents. For the Z they liked the AC wire to the clutch and then the hood insulation. I also used wire loom for covers. Along with what others suggested for fixes , I also use liquid tape that is brush on and water proof when dry. it seals any tape wrap or spliced connectors that aren't perfect.
