Forums/Z31P/z31-repairs-forums electronics/Wire shielding question.
Imported from Z31Performance.com Forums{{#if:rangerkid| — original post by rangerkid}}{{#if:2016-03-19 03:38:09|, posted 2016-03-19 03:38:09}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/25661-wire-shielding-question.html|
rangerkid: (2016-03-19 03:38:09)
So I'm basically reworking my entire engine harness, getting rid of useless connectors, replacing wires, shortening ect. My problem is, I've searched on here but can't find a straight answer. Does the wire shielding for the CAS and MAF need to be wired into the ECU ground Pin #'s 35 & 27? Or can I just splice it into the body somewhere near the ECU? Also, would it be beneficial to pull a part the gray cable at the opposite end, pull out the shielding and ground it. Everything I read said it needs to be grounded at both ends.
