Forums/Z31P/z31-repairs-forums electronics/What the £Ãâ¬%$! Is this?
Imported from Z31Performance.com Forums{{#if:Dr1ft3aby| — original post by Dr1ft3aby}}{{#if:2017-02-17 21:24:15|, posted 2017-02-17 21:24:15}}{{#if:13| · 13 post{{#ifeq:13|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/534391-what-the-is-this.html|
Dr1ft3aby: (2017-02-17 21:24:15)
So i was gonna run my obd today. Got the seat out… And this is what i find. Any ideas whats going on here?
FrozenZ: (2017-02-18 00:09:30)
It's the antitheft stuff, I think?
BLITZERKING1: (2017-02-18 00:56:50)
The GLL models had the amp under the passenger seat
tcfs: (2017-02-20 05:09:30)
The antitheft box is located under the passenger seat. The amp is also located under the passenger (I think) on models that have it.
turbofedz: (2017-02-21 05:56:10)
Yes that is the radio amp.
Augustus Maximus: (2017-02-22 09:39:13)
Some rusty, crusty crapola
Dr1ft3aby: (2017-02-27 06:24:23)
So then is there not an obd in here somewhere?
BLITZERKING1: (2017-02-27 07:30:18)
The ecu's in z31s do have diagnostic codes you can lookup. I believe the ECU flashes lights to represent codes. Read more here https://dev.z31library.com/xenonzcar_archive/z31/ECUcodes.html
Dr1ft3aby: (2017-02-27 11:23:42)
But where is it? I thought under the passenger seat?
kaur: (2017-02-27 11:58:46)
Passenger side kick panel. Behind the plastic trim piece under the glove box on the side of the body. Have you checked the FSM and XenonZcar?
Dr1ft3aby: (2017-02-27 12:23:07)
Ya ya. Ive got the fsm right here. Im gonna see if i get a code off the com
dafunkmonster: (2017-02-27 20:02:40)
You're probably referring to the standardized OBD-II plug that is found on all late model vehicles. The Z31 predates this common standard.
BLITZERKING1: (2017-02-27 21:40:45)
Yeah. The 96 300zx is the only 300zx with OBD-II. Vehicles before 1996, so any z31, does not have OBD-II
