Forums/Z31P/z31-repairs-forums electronics/Updated Transistor ??
Imported from Z31Performance.com Forums{{#if:JSM| — original post by JSM}}{{#if:2018-08-10 00:21:12|, posted 2018-08-10 00:21:12}}{{#if:13| · 13 post{{#ifeq:13|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/540568-updated-transistor.html|
JSM: (2018-08-10 00:21:12)
I thought I read the Z31at some point got an updated transistor. Is this it? Are these better or same as the PRW-2 upgrade? This came of an 89 NA.
Z_Karma: (2018-08-10 17:24:16)
I upgraded the one like that in my 88T to the PRW-2 style. Not sure if the internals are different but went ahead and did it anyway as the PRW-2 modules are easy to get at the pick-n-pull for cheap.
jdmlegends: (2018-08-12 02:32:16)
Hard to believe the tiny PRW-2 costs $151 new from Nissan. It appears to be the same exact part number for cars like the Maxima, Altima, and Pathfinder.
Dunkine: (2018-08-12 04:14:52)
That's what my 89 had on it. I upgraded it to the PRW-2 also.
Not too bad of a list price for a brand new from nissan ignition control module. Get a wholesale account there and it will slash those prices. I got all mine used for cheap.
kaur: (2018-08-12 07:43:13)
{{#if:jdmlegends|jdmlegends wrote:|Quote:}}
It's a power transistor, they don't come too cheap. Even Chinese ones are pretty expensive as new parts.
Z_Karma: (2018-08-12 21:29:09)
The ones i get from the pick-n-pull often fall into the cracks of my tool bag and can sometimes go unnoticed until
i get home. shame really. They're usually just priced as a "relay" and around 5 bucks.
JSM: (2018-08-13 19:59:39)
I tend to just dump my bag and put all the little “”””” ‘do dads’ on the counter. Typically they only mark the big stuff.
mk1turbo: (2019-01-09 14:05:50)
I was wondering if anyone would know if the power transistors are interchangeable over the years? Hopefully I'm not thread jacking, I figured this was related.
I have an '86 na that I believe has a bad transistor - I don't have any spare parts so I was considering buying the newer version but I wasn't sure if they worked differently or just had different plugs or something simple. I'd really appreciate any info or advice before moving ahead.
IL300zxt: (2019-01-09 15:46:02)
https://dev.z31library.com/xenonzcar_archive/z31/prw2.html
They are usually like 15$ on ebay at this point. Switch two wires per the linked guide, plug is the same. Very simple.
zachary.ard: (2019-01-09 19:36:51)
Its plug and play at this point no need to even try to fool with the harness.
https://z31parts.bigcartel.com/produ…n-play-adapter
mk1turbo: (2019-01-09 19:50:05)
perfect! that's exactly what I was looking for - thanx
JSM: (2019-01-09 22:57:07)
{{#if:mk1turbo|mk1turbo wrote:|Quote:}}
Yep I got the same one.
mk1turbo: (2019-01-17 00:56:44)
Thanx again - I found a good used PRW-2 on ebay for $10 and installed it already. Unfortunately, I still do not have spark (or more so, its inconsistent - sparks occasionally for a bit and then stops), which seems the same as it was w/ the original transistor…
