Forums/Z31P/z31-repairs-forums electronics/Pump below radiator
Imported from Z31Performance.com Forums{{#if:300zxturboftw| — original post by 300zxturboftw}}{{#if:2015-07-24 03:42:10|, posted 2015-07-24 03:42:10}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/25213-pump-below-radiator.html|
300zxturboftw: (2015-07-24 03:42:10)
My cars HVAC does not work and it used to with my similar set-up. It only blows cold air and won't switch. Have tried everything including canister and I can't even get it back to only blowing hot air on defrost! Recently had my car in the air and saw a pump of some type in front of the radiator…assuming this is some sort of air pump? Anyhow there is a white tee that comes off the pump with 2 detachable pieces. Inside is a little spring and washer. One side was completely cracked off. Wondering if this was part of my issue? What piece is this as I'm having trouble finding it on courtesyparts - what does the pump do also (again right beneath the radiator in the front bumper).
If anyone could guide me to replacement parts or let me know if I can just throw a normal tee in place of it without all the springs inside to block the vacuum that would be great.
Parker: (2015-07-24 04:05:08)
That's not the headlight washer pump, is it?
300zxturboftw: (2015-07-24 04:23:12)
That makes a lot of sense…considering I took out the washer tank up front…
