Forums/Z31P/z31-repairs-forums electronics/New Distributer Replacements - comments
Imported from Z31Performance.com Forums{{#if:dbruce| — original post by dbruce}}{{#if:2020-11-28 20:01:04|, posted 2020-11-28 20:01:04}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/545640-new-distributer-replacements-comments.html|
dbruce: (2020-11-28 20:01:04)
Has anyone have comments on distributor replacements ? compared to the nissan oem Hitachi Type
https://www.rockauto.com/en/moreinfo…209530&jsn=826
Spectra Premium all new Distributors deliver powerful consistent OE spark for maximum combustion efficiency, accurate timing, and rock solid high-rpm performance.
Benefits Include:Includes NEW OE style cap and NEW rotor 100% endurance & life cycle tested to ensure they meet OEM specifications for fit, form and performance.
badq45t: (2020-12-02 01:49:09)
I have always opted for OEM on this component, I don't see an upside unless you see a big savings seems like the OEM is still available brand new so I would stick with original OEM
Z_Karma: (2020-12-02 22:47:07)
Personally I've never had good luck using aftermarket cap and rotor kits on my 84T.
The other critical component being the CAS, and again, I use the newer oem CAS
from the VG33, granted they are used from J-yard cars, but I'd still will usually trust used OEM over budget aftermarket.
So i wonder if they are selling a rebuilt OEM core with aftermarket components. The price is tempting, not so much if you had to go oem on the cap and rotor because of misfires.
dbruce: (2020-12-03 16:09:52)
AS far as I know these have no remanned parts in these, .they are all new … rockauto has the best price 117 …
Mainly I'm looking at my 85 with over 220K miles and thinking getting a new dist might be a good idea
You can use an oem cap/rotor on it just like the oem dist
It comes with a new cas plus the new bearings and the new gear itself … the remanned oem dists are about $260 plus core charge compared with 120 for the spectre … Also I'm thinking just having a spare around might be a good idea ( having 2 z31's)
https://www.ebay.com/itm/New-Dist-Sp…4383.l4275.c10
