Forums/Z31P/z31-repairs-forums electronics/NA2T Detonation Knock Sensor Location
Imported from Z31Performance.com Forums{{#if:Student005| — original post by Student005}}{{#if:2018-08-04 22:34:39|, posted 2018-08-04 22:34:39}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/540506-na2t-detonation-knock-sensor-location.html|
Student005: (2018-08-04 22:34:39)
Hey yâall so hereâs the run down I have an 86 NA engine that I am slapping all the turbo components on and putting in a 85 Turbo chassis which is where most of the turbo parts are from. I have the engine out with 80% of turbo stuff on and need to install knock sensor. I read elsewhere it says stock Location is on passenger block below cyl #1 and I found the suspected spot and removed the bolt come to find out Haynes states that is a âcoolant draincockâ but the picture representation they use is an NA. Is that the actual spot, on the coolant channel?
dbruce: (2018-08-05 14:35:59)
https://youtu.be/RoI5PIj6CY0?t=376
shows location of knock sensor How To Remove A 1984-1989 300ZX Engine (VG30ET)
jdmlegends: (2018-08-05 21:12:56)
The approximate location is also shown in the FSM.
Student005: (2018-08-06 11:48:22)
Okay thanks yâall. Whatâs funny is I have seen that video before didnât notice he was talking about the knock sensor.
Student005: (2018-08-07 16:48:33)
What seems to be the right location on my block is wayyyy to small to accept the knock sensor I have. The one I have is from an 88 I wonder if that makes a difference. I did find a non-water channel hole to put it in though, does anyone thing this would not function properly in this location?
Student005: (2018-08-07 16:51:47)
Haha after further review of the video I find that my new location is in fact the correct location. Thanks for the help yâall
