Forums/Z31P/z31-repairs-forums electronics/Map light
Imported from Z31Performance.com Forums{{#if:Salster86| — original post by Salster86}}{{#if:2018-07-02 20:21:08|, posted 2018-07-02 20:21:08}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/540061-map-light.html|
Salster86: (2018-07-02 20:21:08)
Good day all, does anyone know how to remove the map light in the front center of the ceiling of a Z31 ? I need to replace one of the bulbs but am afraid to pull on it without first asking…
Z_Karma: (2018-07-02 21:05:51)
It's just clipped into place, usually helps to pull down more on one side first.
The plastic that holds the clips (they're just staked in) into place can be brittle with age, so care is justified.
Dunkine: (2018-07-02 21:12:18)
Two sets of metal clips on each side. Be careful of the plug in the back (above the switches), you can break where it plugs into the unit when pulling it down. The clips are on the side and there is a metal "ring" in the headliner that it pushes up into, that's why it's so hard to get down.
