Forums/Z31P/z31-repairs-forums electronics/Harness connector
Imported from Z31Performance.com Forums{{#if:dgz32| — original post by dgz32}}{{#if:2019-09-02 22:04:33|, posted 2019-09-02 22:04:33}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/544309-harness-connector.html|
dgz32: (2019-09-02 22:04:33)
I'm rewiring my car and need some help with a couple of connectors.
Pic shows a small yellow'ish connector is which exits the loom with the oil pressure switch connector on the pass-side. Not turning up much with research. Anyone know?
Also, I don't have the wire/connector to the blade connector on the starter. From what I can tell, this the inhibitor switch which should be coming off the inhibit relay forward of the pass-side relay box. Is this correct? Can someone tell me where it exits the engine room harness?
dgz32: (2019-09-04 16:40:28)
Re the blade connector at the starter, the connector coming off the engine room harness at 14E appears to be it. But the drawing is clearly not showing a blade connector. Can anyone tell me if there's a sub-harness ​​​that goes between it and the starter?
AzureblueZ: (2019-09-04 19:39:06)
I asked my super knowledgeable z31 buddy. He said: "I think the wires he is looking for are on the sub harness that goes to the alternator."
Z_Karma: (2019-09-04 19:45:01)
Just verified on my SS 820. It's the connector for the oil temp sensor that is threaded into the passenger side of the oilpan.
dgz32: (2019-09-06 15:24:04)
{{#if:AzureblueZ|AzureblueZ wrote:|Quote:}}
I didn't see it on the MT/alternator harness that I have—which came off an '87. Have a spare harness from an '84 which also didn't have it. Wonder if it's a wire that's bundled with that harness but not connected to it directly?
There's an '87 car in a parts yard not too far from me. I may try to head over there and see what's up tomorrow.
Right! Thank you, sir. I'd like to think I'd have figured that one out…eventually.
