Forums/Z31P/z31-repairs-forums electronics/Factory amp location?
Imported from Z31Performance.com Forums{{#if:albionwanderer86| — original post by albionwanderer86}}{{#if:2017-09-11 02:17:32|, posted 2017-09-11 02:17:32}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/536903-factory-amp-location.html|
albionwanderer86: (2017-09-11 02:17:32)
So… I have an '85 2+2 GLL, and from what I've read, I should have a factory amp underneath the passenger seat that can be "bypassed" to run an aftermarket stereo. I've recently removed my passenger seat to replace it, as well as repair some rust damage, and all I found underneath it was two components, one of which is clearly anti-theft. So, where exactly is this "amp"?
What was under my seat…
Dunkine: (2017-09-11 04:53:49)
Someone already removed it. It plugs into that connector with the yellow on the back.
The factory radio has a round plugged cable that runs down to the amp, the amp amplifies that and sends it to your speakers via the plug with the yellow on it. So you need to run your speaker outputs from your new radio under the carpet to that plug.
You can either splice / hack into it or you can get a cable from Crutchfield.com so you don't have to.
Here's the harness I got from Crutchfield.com. I added the wire covering to make it look stock. The factory amp is laying on the floor in the background:
[archived image: Lz5HK2F.jpg]
You plug that in under the seat and run it under the carpet up to the back of the radio:
[archived image: 6vbFDFn.jpg]
And out the opening:
Then solder that to your new radio speaker outs:
[archived image: jIcz3B9.jpg]
Doing this saves you from having to run new speaker wires throughout the car. You can also get the plastic single din faceplate from Crutchfield or Amazon to install the radio.
albionwanderer86: (2017-09-11 11:53:39)
Oh, okay. Thanks!
albionwanderer86: (2017-09-12 00:22:14)
You wouldn't happen to have a part number for that Crutchfield harness, would you? I'm on their website and can't find anything like that…
Dunkine: (2017-09-13 01:10:48)
Metra 70-1741 Receiver Wiring Harness
after you punch your vehicle in, go down to "Parts & Accessories".
then click on "Wiring Harenesses"
comes with the power hareness too.
They also have the stuff to make steering wheel controls work and the infamous Metra 99-7411 Dash kit to install single DIN radios, but sometimes it's cheaper on Amazon.
