Forums/Z31P/z31-repairs-forums electronics/Can't find turn signal flasher
Imported from Z31Performance.com Forums{{#if:i r teh noobz| — original post by i r teh noobz}}{{#if:2017-08-15 20:49:47|, posted 2017-08-15 20:49:47}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/536644-can-t-find-turn-signal-flasher.html|
i r teh noobz: (2017-08-15 20:49:47)
Trying to access the turn signal flasher relay to test it, I can't seem to find it anywhere. The FSM suggests that it's behind the gauge cluster, do I need to remove the cluster?
Dunkine: (2017-08-16 14:16:17)
Right of the steering column, left of the accel pedal, little black box (relay sized).
You don't have to remove anything to see it, flashlight helps, it's dark up there.
FlyingT: (2017-08-22 20:13:30)
Mine was behind the ash tray and was laying on the transmission hump
i r teh noobz: (2017-08-26 18:06:39)
I found it, right by the steering shaft like Dunkine pictured, My car is an 88T, maybe the Zenki has it behind the dash.
I smacked it on the table a few times and all is well again. I've been manually blinking my signals since BZF 2014 (flasher failed after a big storm). Thanks for the help.
