Forums/Z31P/z31-repairs-forums electronics/Battery fuse link?
Imported from Z31Performance.com Forums{{#if:Eric9006| — original post by Eric9006}}{{#if:2015-01-16 00:29:48|, posted 2015-01-16 00:29:48}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/24675-battery-fuse-link.html|
Eric9006: (2015-01-16 00:29:48)
Friend attempted to jump start my car and had the jumper cable on opposite stuff. Ground to postive and vice versa… It ended up burning through a wire in a box in front of the battery. I believe it is a fusible link but can't seem to find anything online to order a new one… What is this excact name of part so I can order it? Thanks in advance
Z_Karma: (2015-01-16 01:36:20)
Same thing happened to me, luckily the fuse did it's job and nothing else was damaged.
The exact name is "Fusible Link" and they are available through MSA
http://www.thezstore.com/page/TZS/PROD/12-4343
Or Courtesy Nissan
http://www.courtesyparts.com/24161-l…-p-144223.html
Or at your local Pick-n-pull for ?$
Eric9006: (2015-01-16 01:40:48)
Thank you. I tried finding images for that and it didn't work
BlackBeast: (2015-04-26 21:09:00)
Is the MSA fusible link just wire or is it the whole connector as well?
xenonxiii: (2015-04-28 09:02:41)
allthingsz.com
