Forums/Z31P/z31-repairs-forums electronics/85 analog instrument lighting
Imported from Z31Performance.com Forums{{#if:reddzx| — original post by reddzx}}{{#if:2015-05-24 04:17:22|, posted 2015-05-24 04:17:22}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/25052-85-analog-instrument-lighting.html|
reddzx: (2015-05-24 04:17:22)
So I don't ask for help very often but I did some searching and have not found an answer.
The instrument cluster illumination is dark. I swapped the switch from the parts car but it may be bad.
Is there a fuse or relay for the speedo/tach lighting? All the warning lights come on just no lights for the gauges with the lights on at night
les_joey_paul: (2015-05-24 11:59:36)
Not 100% but everything in my 85 that comes on with the parking light switch is red wire with a green tracer.
reddzx: (2015-05-25 15:41:23)
intermittent wiper function is working. I'm going to check the dash harness connections next.
