Forums/Z31P/z31-repairs-forums electronics/5 pin din amp wiring
Imported from Z31Performance.com Forums{{#if:TorontoZ| — original post by TorontoZ}}{{#if:2019-02-25 04:45:34|, posted 2019-02-25 04:45:34}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/542526-5-pin-din-amp-wiring.html|
TorontoZ: (2019-02-25 04:45:34)
Does anyone have the pinout of the 5 pin din or a radio manual that includes the 5 pin din connector that comes out of the radios to go to the amp for the rear speakers? Would be appreciated thanks
Z_Karma: (2019-02-25 18:50:45)
As requested: previous post.
https://z31performance.com/forum/z31…am-help-needed
The only thing i have is the 5pin DIN pinout for the Hitachi CSK-7101ZG (no equalizer)
This is from the stereo side. The earlier Z31 amp/stereo combo used chassis ground for the negative.
If you compare that to this aux amp image for a 2002 Altima (that i found online)
It might be possible that your audio signals are on the same as the altima (atleast the positive outputs match)
You should be able to test this by connecting a scrap headphone speaker to those pins (4&6 or 5&7) and listen
for sound from the headunit.
A loud pop followed by smoke means that's not it and you shorted 12V across the voice coil, which is why you use a scrap speaker.
