Forums/Z31P/z31-repairs-forums electronics/1985 300zx no power?
Imported from Z31Performance.com Forums{{#if:Eric9006| — original post by Eric9006}}{{#if:2014-11-26 02:01:05|, posted 2014-11-26 02:01:05}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/24541-1985-300zx-no-power.html|
Eric9006: (2014-11-26 02:01:05)
Car starts and drives fine. Only thing that does work is that. No digital dash turns on. No brake lights or reverse lights. Pop-up head lights don't work. No wipers. No radio. No interior lights. No windows. I just replaced alternator and let the battery charge a little before driving again but still same problem. Where should I start to try to find the problem? Thanks in advance
C.Gesler: (2014-11-26 14:03:56)
Sounds like you are not getting power to your acc circuit. Check fuses, fuseable links, relays and ignition switch and of course any related wiring. Thats where I would start.
Eric9006: (2014-11-26 15:18:39)
I don't know if this helps any but I just switched alternators. Sometimes if I rev the car over 4,000 Rpms then it'll work everything but cut out while driving
