Forums/Z31P/z31-repairs-forums electronics/12v power outlet
Imported from Z31Performance.com Forums{{#if:Eric9006| — original post by Eric9006}}{{#if:2015-02-11 20:16:32|, posted 2015-02-11 20:16:32}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/24728-12v-power-outlet.html|
Eric9006: (2015-02-11 20:16:32)
I am trying to have the convience of having another 12v outlet. I all ready have it drilled into my rear cabin area. Only problem I'm having is with the wiring. I originally was going to do this off a toggle switch but that is really inconvient so I'm wanting it to be set up off my ignition switch. I'm not too good with wiring but I can do the basic so take pity on me. Which wire and where is it located do I want to have this setup and turn off on the ignition switch?
amreboot: (2015-02-11 20:28:50)
Get a multimeter and see whats a 12v-on wiring in the dash. Then get a relay and create a circuit.
Google how to create a 12v-on relay circuit.
Z_Karma: (2015-02-11 20:32:57)
An easy and safest way to do it is just to tap into the same wire that plugs into the back of your cigarette lighter
with a bullet connector with one of these: gBkZtgg.jpg
Run the ground wire (-) to the chassis.
That way, you are using the same fuse as you normally would for the lighter circuit.
