Forums/Z31P/z31-repairs-forums electronics/*FIX* Running HVAC controls WITHOUT vacuum canister
Imported from Z31Performance.com Forums{{#if:Ubernathan| — original post by Ubernathan}}{{#if:2018-10-02 12:45:46|, posted 2018-10-02 12:45:46}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/electronics/541258-fix-running-hvac-controls-without-vacuum-canister.html|
Ubernathan: (2018-10-02 12:45:46)
- Mods feel free to move*
- For N/A models only, you need a vac canister for turbo models due to boost being introduced to the system that runs on vacuum*
So this is my 2nd post, but given I had difficulty finding a clear solution, I'm hoping/feeling this may help shed some light on the daunting HVAC / Defrost / Heat problem.
I was blessed with a car that had the vac canister ripped out and no regards to what went where as far as engine bay lines, so I ran a line from the plenum --> 1-way check valve --> T-fitting --> (1 line to top of water cock solenoid, other to inside firewall to T-fitting supplying all under-dash vac sources). Made a short 3min video explaining and showing this as well for those of you who are visual like I am. Hope this helps some out there with the same problem.
Dunkine: (2018-10-03 00:16:20)
Nice Vid
Turbos have a check valve on them already.
A few have done something similar with the Vac canister to keep it from going to defrost when accelerating hard.
Have you tested it under load yet?
Ubernathan: (2018-10-03 02:55:13)
Nice Vid
Thanks, just trying to help someone out there. Under load it functions just as it should, so I was really happy about that. I need to charge my AC but I could feel the different between air when the solenoid would open and close under heat/cold.
