Forums/Z31P/z31-repairs-forums cosmetic-interior-exterior-aa/rust fixable?
Imported from Z31Performance.com Forums{{#if:zwp1990| — original post by zwp1990}}{{#if:2015-04-08 18:05:41|, posted 2015-04-08 18:05:41}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/cosmetic-interior-exterior-aa/24921-rust-fixable.html|
zwp1990: (2015-04-08 18:05:41)
If it is how would I go about doing it?
amreboot: (2015-04-08 18:18:43)
How do you go about fixing that?
Cut it out and weld in a replacement.
Z_Karma: (2015-04-08 18:47:49)
Either find a rust free donor to cut clean pieces from, or make your own.
And fix the probable water leaks in the T-tops that caused those areas to rust out.
For an example, this guy is doing a shit-ton of rust repair on his Z31.
http://z31performance.com/showthread…gian-Z-project
zwp1990: (2015-04-08 19:49:45)
Do I use sheet metal or another type? Never done body Work so I'd obviously have help but trying to learn. Thanks.
dark-divx: (2015-04-08 19:54:41)
The only thing you can do is cut it out and welding new selfmade/donor parts
dark-divx: (2015-04-08 19:56:22)
{{#if:zwp1990|zwp1990 wrote:|Quote:}}
You take sheet metal. 1mm is enough. But I uses 2mm in the bottom.
You cut it out and you made a new part with the same shape.
In my topic you can see the same repair that you need to do.
