Forums/Z31P/z31-repairs-forums cosmetic-interior-exterior-aa/OEM Shiro front spoiler damage.
Imported from Z31Performance.com Forums{{#if:cmgreen22| — original post by cmgreen22}}{{#if:2016-06-18 19:14:49|, posted 2016-06-18 19:14:49}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/cosmetic-interior-exterior-aa/531175-oem-shiro-front-spoiler-damage.html|
cmgreen22: (2016-06-18 19:14:49)
Can this be repaired? Do anyone have knowledge or experience repairing Shiro spoilers? I still have the original spoiler bracket and would like to stay with this spoiler if at all possible. Any advice on how I should proceed will be appreciated. Thanks.
Z_Karma: (2016-06-20 17:40:34)
I'm experienced in cutting one up to fit in the garbage can, but that one was beyond repair.
It's a steel frame with a dense foam beneath a type of flexible urethane coating.
You might try cutting out the damaged areas using a sharp utility knife and rebuild the shape using
a dense foam, I've read that some use the pink construction foam at Home Depot for shaping custom parts.
Watch all the youtube videos you can about repairing urethane bumpers and see what products are used.
There are a few from 3M and possibly Evercoat. I did some similar research a few years ago but never
did any actual repairs.
cmgreen22: (2016-06-29 17:51:41)
Thanks for your input. I will research this more and see what I come up with. Thanks again.
