Forums/Z31P/z31-repairs-forums cosmetic-interior-exterior-aa/Name That Part
Imported from Z31Performance.com Forums{{#if:jdmlegends| — original post by jdmlegends}}{{#if:2018-10-12 01:29:13|, posted 2018-10-12 01:29:13}}{{#if:11| · 11 post{{#ifeq:11|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/cosmetic-interior-exterior-aa/541345-name-that-part.html|
jdmlegends: (2018-10-12 01:29:13)
Does anyone know what the name of this part is? It's a perforated metal bar that runs across the undercarriage. It is located before the sub-frame and behind the catalytic converter. I don't have an actual photo of it, so I got one from a very detailed plastic car. [archived image: smile.png]
jdmlegends: (2018-10-12 01:33:47)
I think it's called the inner rear cross member or member-cross, rear inner in Nissan lingo. Just wanted to confirm.
Reds89: (2018-10-12 02:58:31)
That is a nice model. What kind/brand is it?
bonfire79: (2018-10-12 12:28:28)
looks like it might be the 1/25 scale Tamiya kit. these Z31 and S130 model cars are getting harder to find. i managed to get two of 'em a few years ago
Bon
bonfire79: (2018-10-12 12:41:48)
{{#if:jdmlegends|jdmlegends wrote:|Quote:}}
i don't remember seeing one on my car, but you can check nissanpartsdeal.com; they have some pretty good parts diagram. maybe it will show that one.
Bon
mwolvinm: (2018-10-12 16:55:52)
found it… Member-cross, rear inner; 74882
MEMBER-CROSS,REAR INNER
Part Number: 7586101P00
MSRP is 83.65--- not bad....Oh. And it looks to be still available from Nissan.
jdmlegends: (2018-10-13 00:34:34)
I am not sure what model the scale plastic car is. This is the most detailed one I've seen to date.
Recently, I've discovered many parts I thought were discontinued are still available from Nissan or are available in limited quantities. Of course, this has depended on which wholesale parts website I visit and which local dealer as well. Perhaps different dealers have access to different regional surplus depots. For example, on the East Coast it seems like the parts might come from a warehouse in Tennessee. When I was in Ventura, CA, the parts might have come from the Carson City area.
Anything under 100 bucks is good too. [archived image: smile.png]
elba85Z: (2018-10-18 14:45:09)
Just picked up a couple of these model kits from Japan a couple weeks back. My inner crossmember that basically does nothing than holds up the exhaust and if your driveshaft ever goes,keeps it from hitting the ground, is going to be rebuilt by my father in law next door. (We also need to repair the frame where it bolts to, as rust has caused it to come unattached from the frame)
Pace: (2018-10-18 16:13:13)
Pretty sweet detailed model.
I removed the inner crossbrace from my Z31. The original was bent upward and rubbed the exhaust. I haven't noticed much of a difference without it, but I'm sure it helps to laterally support that part of the chassis to a limited extent.
Z_Karma: (2018-10-18 17:21:44)
Back in the day AL87T (Dunbar Motorsports) was making replacements out of just a 1/4" or 3/16" aluminum bar.
jdmlegends: (2018-10-23 20:47:50)
{{#if:Pace|Pace wrote:|Quote:}}
Back in the day, I used to think a lot of the parts on these cars weren't needed, or were unnecessary. However, over the years I've learned that each part was designed by the engineers who built the car and does serve a specific purpose. For example, a lot of people delete the clutch damper because it's in the way and makes it easier to bleed the clutch. However, it's essential when it comes to reducing vibration in the drivetrain and increasing its longevity.
Like you said, it's most likely that the inner rear cross member stabilizes the car on curves to a degree and probably reduces the twisting and turning motion on the chassis. And since it's unibody, it may prevent having to have your frame straightened in the future.
On one of my Z's, it's all bent up. Looks like someone bottomed out but the rest of the chassis appears to be good.
