Forums/Z31P/z31-repairs-forums cosmetic-interior-exterior-aa/Door panels
Imported from Z31Performance.com Forums{{#if:Eric9006| — original post by Eric9006}}{{#if:2014-09-10 18:50:12|, posted 2014-09-10 18:50:12}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/cosmetic-interior-exterior-aa/24289-door-panels.html|
Eric9006: (2014-09-10 18:50:12)
I'm wanting more of a black interior, I've found carpet but I can't seem to find the door panels, I was wondering what's the cheapest way to make door panels black while maintaining a decent look of it.
FlyingT: (2014-09-10 20:00:27)
Reskin them in the vinyl color of your choice. Easier than I thought.
The arm rests have been changed to black too.
[archived image: DSCF0088_zpsd1546173.jpg]
[archived image: DSCF0086_zpsbf87095c.jpg]
[archived image: DSCF0089_zps975edd4d.jpg]
Eric9006: (2014-09-10 20:06:36)
Where did you get that vinyl? It looks pretty good
FlyingT: (2014-09-10 20:45:49)
Metro restyling. What you see on the door is vinyl carbon fiber fabric, like a cloth, laid over a 1/8 inch foam backing. The carbon fiber effect in normal light is not any way near as noticeable as when the camera flashes.
http://www.metrorestyling.com/Metro-…lkcffabric.htm
This looked so good I decided to experiment with stretchable vinyl sheets. The below pictures are their 3M Di-Noc carbon fiber vinyl sheets. With a hair dryer, you can cover an outside mirror, it stretches so much. I decided to cover the seat back fiber boards with this stuff, and then decided to go for it and cover the lower inside trim of the entire car. This is what I have done so far. Next are the shock tower trim pieces. That will be a challenge with the many curves and shapes. If I don't like what I am doing, you can always pull this stuff off and go back to the original 30 year old plastic.
[archived image: DSCF0008a_zps49538aa3.jpg]
[archived image: DSCF0001a_zps01d9948f.jpg]
[archived image: DSCF0036_zps88be45b1.jpg]
85z31t88: (2014-09-11 05:48:43)
carbon fiber +10 hp for each panel covered.... duh. [archived image: tongue.png]
to the op-this stuff is sweet and I may have to experiment with it as well. Can we get an installed pic of all the panels in the car when done?
