Forums/Z31P/z31-repairs-forums cosmetic-interior-exterior-aa/Clearcoat Body Repair
Imported from Z31Performance.com Forums{{#if:dbruce| — original post by dbruce}}{{#if:2018-09-06 14:40:56|, posted 2018-09-06 14:40:56}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/cosmetic-interior-exterior-aa/540976-clearcoat-body-repair.html|
dbruce: (2018-09-06 14:40:56)
I was wondering if anyone has been successful in repairing damaged clearcoat … I have seen some video's showing the process of sanding and respraying with 2K spay can clearcoat with pretty good results .
My 1985 blue mist metallic has a two bad areas that I want to do something about but I don't want to make it worse that it is .
2k clearcoat:
https://www.amazon.com/Spray-High-Gl…/dp/B0043B7UQY
Z_Karma: (2018-09-06 20:23:10)
Well, it's only going to get worse on it's own, so you would just be slightly expediting the process if it failed [archived image: smile.png]
I have got to do the same with my black 84T where i gave it premature male pattern baldness from a tarp i used last winter when we had record rainfall, but it's all the way down to the primer in spots. The whole T-bar roof probably needs to be resprayed.
dbruce: (2018-09-06 22:32:57)
these are about the best examples I could find:
https://www.youtube.com/watch?v=Hj9VqSnT-bs
How to Repair Clear Coat Fix 100% all types
Mar 18, 2018
How to guide on repairing old peeling or damaged clearcoat with amazing results you can do at home for small money and with professional results!. This guide is a complete fix for all types of clearcoat failure no matter the kind!
https://www.youtube.com/watch?v=lbSIjsUeWZQ
How to Repair Damaged Clear Coat - Auto Body Repair Hacks Revealed
https://www.youtube.com/watch?v=M_v8qPqPmr0
Can You Repair Badly Damaged and Peeling Clear Coat?
