Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/turbocharger oil drain.
Imported from Z31Performance.com Forums{{#if:darkside| — original post by darkside}}{{#if:2011-05-29 11:47:41|, posted 2011-05-29 11:47:41}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/14558-turbocharger-oil-drain.html|
darkside: (2011-05-29 11:47:41)
is this the correct oil drain for our t3? if so it should also work for holsets? either way it's pretty cool.
http://www.summitracing.com/parts/RUS-697070/
and this looks like a handy oil pan turbo drain fitting:
http://www.summitracing.com/parts/RUS-697090/
Russell is on the ball
Careless: (2011-05-29 14:26:45)
you could just use two of the first ones since it has an o-ring fitting and just use an o-ring fitting to back the flange when you fasten it to an N/A drain pan.
