Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/suggestions for cam gear settings
Imported from Z31Performance.com Forums{{#if:BlazzinZ88| — original post by BlazzinZ88}}{{#if:2011-05-26 19:00:45|, posted 2011-05-26 19:00:45}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/14542-suggestions-for-cam-gear-settings.html|
BlazzinZ88: (2011-05-26 19:00:45)
I am going to be installing my built engine over the weekend and I will be using morgan style cam gears. I was going to lean towards getting more torque but am afraid I might exceed the dxd stage 4 clutches torque capacity. Any suggestions on where to place them? Car will be running nistune, 480cc injectors, walbro fuel pump, t3/t4 said to be good to around 550-600hp, forged pistons, brc 8.5:1 pistons, balanced, external wastegate, 3" turbo back no cat, again dxd stage 4 with fidenza flywheel, afco radiator, electric fan, large NPR intercooler, isky cams, ferrera valves, schnieder springs, new OEM lifters. I am planning revving to around 6700rpm maybe more if the car seems like it can take it. Specs for the cams are as follows from the sheet isky sent me with them.
Grind - 280-MEGA HYD
270-MEGA HYD
Lobe Center 119 deg
valve lift is calculated with rocker ratio of 1.5
INTAKE TIMING
DURATION 280 DEG
OPEN 21 BEFORE TDC
CLOSE 79 AFTER DBC
CAM LIFT .323
VALVE LIFT .485
VALVE LASH .000
EXHAUST TIMING
DURATION 270 DEG
OPEN 21 BEFORE TDC
CLOSE 74 AFTER DBC
CAM LIFT .310
VALVE LIFT .465
VALVE LASH .000
OVERLAP 37 DEG
THE ABOVE TIMING IS CHECKED AT (OPEN) LIFTER RISE
THE FOLLOWING TIMING IS TAKEN AT .050 LIFTER RISE AND GIVES A MORE ACCURATE DETERMINATION OF CAMSHAFT POSITION.
INTAKE
DURATION 232 DEG
OPEN -3 BEFORE TDC
CLOSE 55 AFTER BDC
EXHAUST
DURATION 221 DEG
OPEN 49.5 BEFORE BDC
CLOSE -8.5 AFTER TDC
862sik: (2011-05-27 03:00:55)
Why not get a dyno tune when your done?
NissanEgg: (2011-05-27 03:04:39)
Do you realize how much a PITA it is to set the advance/retard on the Morgan gears? Cam gear has to be completely removed from cam to make a change, then set timing belt again, and possible coolant spills/refills. And trying to do this on/at the dyno. Can get very time consuming and costly very quickly.
Russ84na: (2011-05-27 03:32:12)
That is the best reasoning I have seen expressed for getting a set of my gears…come to think of it that is why I made them the way I did. :lol:
I would go for 3* advance on the setting. It will move your power band down in the RPM range for better response while you are waiting for the turbo to come on. Also +3* will be more streetable. Like you said the only way to really tell is to do a pull at each setting. Check out Jason's dyno sheet in this section http://www.redz31.net/pages/headwork.html
Also I showed some different settings on my NA engine in the Cam gear write up viewtopic.php?f=1&t=17659
If you can't get them exactly where you want I have some in Red and Blue.
862sik: (2011-05-27 04:40:47)
OH I know. But I was just saying to dyno tune it so that he can get the best possible gains for his setup. Im not sure how good is one persons setting to another persons with 2 differnt cars.
aceman: (2011-05-27 05:16:10)
best possible performance is not possible since we dont know your entire setup.
I ran -6 and -9 depending.
if you do road course and backcountry road fun, straight up or maybe +3. if you do alot of highway/dragrace then you may look to retard.
nismopu: (2011-05-27 05:28:30)
^ this!
BlazzinZ88: (2011-05-29 18:18:11)
decided to try -6 since I will be going for more drag racing. Hopefully I will have the car back together tomarrow, just got to put my new steering rack in before I can install the new engine.
