Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/cam grind suggestions
Imported from Z31Performance.com Forums{{#if:mojo| — original post by mojo}}{{#if:2007-12-19 18:45:09|, posted 2007-12-19 18:45:09}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/3837-cam-grind-suggestions.html|
mojo: (2007-12-19 18:45:09)
hey im sending out my stock vg30e cams to schnider racing soon and i was just looking for some sugestions on what grind to get to have good mid range and idle i emailed them and they said a .280 would have a rough idle.
SATAN: (2007-12-20 05:00:06)
http://z31.com/forum/viewtopic.php?t=870
mojo: (2008-01-10 05:05:50)
ok so im going with a .473 lift and a 266 degree cam grind by schnider racing, ill keep you updated when i i get them back.
TurboZkid: (2008-01-10 22:40:33)
i read every thing on the cam degreeing SATAN. but now, what cams would be better than the schindler cams? since i was planning to buy these cams down the road. what other company would you suggest?
SATAN: (2008-01-11 01:35:35)
Well, the problem is the same as with everything else. You get what you pay for. The Schneider cams will run your car and unless you have a good set of cams with the same grind to compare to the Schneider shit cams, you may not even know that you just bought crap for cams.
The only suggestion I have is either the ass rape JWT cams, or to go to a company like ISKY or someone like that, and have a custom set of cams made.
However, to be honest, I haven't come across a set of JWT cams to degree them to see how they stack up either. They could be just as bad, who knows.
benz-tech: (2008-01-11 05:49:26)
Elgin cams in the bay area said they'd regrind me a set for around $350. whatever specs (within physical limits) you want. I'd trust them over Schneider these days.
