Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/What grind shnieder cam
Imported from Z31Performance.com Forums{{#if:barnhart12| — original post by barnhart12}}{{#if:2015-06-04 03:30:39|, posted 2015-06-04 03:30:39}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/25078-what-grind-shnieder-cam.html|
barnhart12: (2015-06-04 03:30:39)
I've got a 87 n/a I was wondering what grind cam should i go. I'm getting Shinder cams with the russ adjustable cam gears. I already have msa headers flomaster exhaust . My goals are a every day driver / weekend freeway racing
turbofedz: (2015-06-05 01:09:47)
Call them maybe stage 1 will be fine for your setup.
PrideZ31: (2015-06-05 09:00:37)
Isn't there a thread on cam info?
NissanEgg: (2015-06-05 13:30:18)
{{#if:PrideZ31|PrideZ31 wrote:|Quote:}}
Yes.
1artworkz: (2015-06-06 17:18:21)
You might want to read this for reference.
http://z31performance.com/showthread…ight=Cam+Grind
ozzyrulez: (2015-06-06 18:33:56)
I've had zero issue with my Schneider cams. Believe it or not shit happens and bad parts leave the shop. I'm a machinist I understand it. One bad cam doesn't indicate they are all junk.
