Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Water Pump Replacement
Imported from Z31Performance.com Forums{{#if:lzrhawk| — original post by lzrhawk}}{{#if:2017-11-08 02:01:43|, posted 2017-11-08 02:01:43}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/537753-water-pump-replacement.html|
lzrhawk: (2017-11-08 02:01:43)
Hi y'all. I'm replacing the water pump in my '85 turbo and trying to stick with genuine Nissan parts. The water pump for the 85 is discontinued but the water pump for the W series engine is still available. Is there any real difference between the two, or should I be fine using the 87-89 water pump for my 85? Thanks!
daniel_pearce: (2017-11-08 02:23:41)
There may be some differences as there were some minor changes to the W series engine over the A and B series engines. It had redesigned water galleries for additional cooling and fully floating piston wrist pins.
Because the OEM water pump for the 84-85 is NLA, I got a Beck/Arnley from RockAuto. Comes with the gasket, and I haven't had any problem with it.
Unfortunately we can't be too picky about where we get our parts from as Nissan has discontinued many critical parts. I imagine one day most Z31's will look like Mad Max's car from the "Road Warrior."
Come to think of it, has anyone built a bucket seat for their dog in their Z31?
lzrhawk: (2017-11-08 03:26:52)
I'm glad you linked this, the Beck/Arnley water pump there on Rock Auto says it covers 84-89 model years and lists both the A/B 21010-02P26 water pump and the W 21010-02P85 water pump as OEM models it replaces. I'll go ahead and grab the W series Nissan water pump and see what happens!
Z_Karma: (2017-11-08 05:29:53)
I've had luck getting remanufactured oem cores at NAPA.
But it's usually the shaft seal/bearing and not a casting that fails, so a cheap aftermarket
pump could very well be remanufacured with the same seal/bearing as a OEM pump.
mwolvinm: (2017-11-08 17:59:23)
Don't forget the timing belt while you're getting the pump. BTW… aftermarket pump. I think autozone or advance on mine. Been there since 2009 with no issues.
Dunkine: (2017-11-12 00:35:30)
You can get the fancy high performance blue belt at Rockauto.
Courtesy still sells 60K Timing Belt Kits. They are around $300
https://www.courtesyparts.com/1984-1989-300zx-z31/
Rockauto also has Timing belt, water pump component kits and they are pretty cheap price wise. If you don't need belts, etc, might be cheaper to piece it either way. There's a discount code on here for rockauto for 5% off I think.
Amazon probably has stuff too as well as a bunch of other places.
A lot of the maintenance stuff fits other Nissans too, the belts fit (off rockauto) INFINITI M30 1990-1992
NISSAN 200SX 1987-1988
NISSAN 300ZX 1984-1989
NISSAN D21 PICKUP 1986-1994
NISSAN MAXIMA 1985-1994
NISSAN PATHFINDER 1987-1994
NISSAN QUEST 1993-1994
