Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/VG33 oil pump
Imported from Z31Performance.com Forums{{#if:darryl rice| — original post by darryl rice}}{{#if:2014-10-20 05:28:41|, posted 2014-10-20 05:28:41}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24424-vg33-oil-pump.html|
darryl rice: (2014-10-20 05:28:41)
I have a question for you guys that are running VG33 oil pumps. What are your oil pressure reading at idle and under heavy acceleration/boost? Also are you guys running stock VG33 oil pumps or have any of you guys had the VG33 oil pumps ported? I'm building a high output VG33 engine and want to know if I should port my VG33 oil pump or not. I want the oil pump to be able to support 30+ psi of boost @
7-8rpm. Also what is to much oil pressure on SOHC VG engines?
