Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Turbo selection help!
Imported from Z31Performance.com Forums{{#if:TurboZkid| — original post by TurboZkid}}{{#if:2010-03-29 05:55:17|, posted 2010-03-29 05:55:17}}{{#if:11| · 11 post{{#ifeq:11|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/9996-turbo-selection-help.html|
TurboZkid: (2010-03-29 05:55:17)
Hey guys, im posting pretty much to get other vg owners opinions about the turbo im seriously thinking about purchasing.
im thinking of going with the precision 6262. its a 62mm Billet compressor wheel and 62mm turbine wheel.its capable of 690hp and i read alot about these turbos on 4cyl evos running upwards of 30psi and 700hp!!!
now im not looking to run 30psi but i am going to be trying to push the stock bottom end of my vg, and also have enough turbo for when I do build the bottom end in the future, so you could say im looking for about that 500 crank hp number for a while
i want to be running the t3 .82ar with 3in vband for the exhaust side. and im also running the stage 3 schindler regrinds with the operation rpm range of 3000 to 7000.
I wonder if it will be a lag monster…? im trying to have a quick spool and a nice top end power band…what does every one think? all feed back would help to make this decision easier!!
[archived image: DSC03333.jpg]
2+2turbo: (2010-03-29 07:47:15)
I am interested too, I am running bigger schneider cams tho, and a satan exh. manifold. considering this one or the 6765 ..
Hitman Z: (2010-03-29 13:17:04)
The 6262 and the 6765 are great turbos to choose and each one of them will give you your desire goal on horsepower with a great engine combination, more than 500RWHP. I personally runs a 6765 in my Z car and works great. Good luck with your project.
Grr: (2010-03-29 15:46:38)
the 6262 is one badass turbo, i would reccommend that choice in BB over the 6265 or 6765 for a street car. On a vg33/34 i would recommend the 6265 though. With your housing selection and the BB option the spoolup would have a threshold of around 2800 with full boost 3200-3400, and will make 600whp at full tilt. I think the stock t3 manifold will be a restriction before the 62mm turbine will be.
TurboZkid: (2010-03-29 17:06:00)
TurboZkid: (2010-03-30 02:41:55)
Bump need some experienced opinions here
Hitman Z: (2010-03-30 02:49:58)
Hi friend. My Z turbo exhaust housing is .81. The cams are Schneider cams 274-70H, fully port and polish heads, performance valvesprings.............
TurboZkid: (2010-03-30 03:00:15)
very nice similar to my setup when does boost come on and wen is it at full boost? bb or journal?
Hitman Z: (2010-03-30 03:16:49)
Boost starts around 3,000 to 3,200rpm with full boost at 3,800rpm. Its BB.
Rick88ss: (2010-03-30 04:29:51)
[quote]Hitman Z wrote:
{{#if:TurboZkid|TurboZkid wrote:|Quote:}}
How much power are you making and how much boost are you running?
I'm going with the same 6765 (without BB) on E85 w/1200cc injectors on a built VG33.
I already have all of the parts. I'm currently building the engine. It should be running before July…I hope.
Hitman Z: (2010-03-30 13:54:01)
[quote]Rick88ss wrote: [quote=Hitman Z]
Hi friend. Well, I am waiting for next week to buy the 1,000cc injectors. Right now the Z has 850cc RC injectors with a Haltech ECU so Im running a low boost setting 15psi. We have currently the same engine and I wish you good luck in your project. By the way the power was 507rwhp with a reading of 11.2 on the wideband, so first I want to install the 1,000cc injectors, use hi octane gas to see how much power I can get from it and to see how much boost in a safe way it can handle. Personally I am expecting between 25 to 30psi but as I said in a safe way so I hope everything goes find with the project.
