Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Turbo rebuild
Imported from Z31Performance.com Forums{{#if:soysauce300zx| — original post by soysauce300zx}}{{#if:2014-03-21 08:15:18|, posted 2014-03-21 08:15:18}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/23489-turbo-rebuild.html|
soysauce300zx: (2014-03-21 08:15:18)
So Ive rebuilt a turbo before but does anyone know how to tell what rebuild kit to get for the T3? Thanks
Axel kain: (2014-03-21 18:29:06)
http://gpopshop.com/garrett-t3-t4-t3t4-kits-2/
soysauce300zx: (2014-03-22 23:43:44)
Okay thanks for the site. I know these turbos are carbon sealed but is their a way to tell if its a 2 or 4 piece kit without taking it apart?
Augustus Maximus: (2014-03-23 02:13:56)
It's the 1 piece carbon encapsulated seal. It can also be converted to dynamic seal by swapping the back plate. Thus be free to use the vastly cheaper and more available kits.
soysauce300zx: (2014-03-23 07:06:42)
Alright so no matter what year turbo its the 1 piece kit and do i stick with the 270 degree or the 360 degree thrust bearing? Also to my knowledge Garret doesn't balance their turbos as a unit. So i can just get the shaft and propellers balanced rather then everything thing am i correct?
PegCityZ: (2014-03-23 16:38:48)
From the site that was linked:
Kit #1: 1-Piece Encapsulated Carbon Seal
-Nissan 300zx '84-'85
Kit #2: 4-Piece Carbon Seal
-Nissan 300zx '85.5-'87
I would assume that the 1-piece is for the oil cooled T3s and the 4-piece is for the water cooled T3s by the dates given.
Augustus Maximus: (2014-03-23 16:40:34)
Things like 360 degree thrust bearing and step gap turbine seal will improve performance. You only need to balance the turbine and compressor wheel and this is only necessary if you didn't mark the compressor wheel in relation to the turbine before you pulled it.
http://shop.midwestturboconnection.c…ancing_c22.htm
soysauce300zx: (2014-03-23 23:34:34)
Okay i see now. I need the 4 piece because i do have a water and oil cooled T3. Thanks for that, ill also look at what year the turbo is to be sure. And as far as the 360 degree thrust bearing and step gap turbine seal go is their any modifications need to be done to the turbo for it to fit? Or do you just slap on? Ive tried to do research on this but i cant find much besides that the 360 degree bearing giving better oil flow. As far as balancing i was going to just mark the turbo up and do with out balancing like i have on the t25 and have had no issues. It depends on how things look when i dig into the turbo. Thanks for the site referral for the rebuild shop i appreciate it.
Augustus Maximus: (2014-03-24 13:31:30)
When I disassembled by water cooled T3 I don't recall seeing a 4 piece seal.
Axel kain: (2014-03-24 20:51:51)
{{#if:soysauce300zx|soysauce300zx wrote:|Quote:}}
Garrett ALWAYS balances their CHRA's. if you paint mark the shaft and compressor wheel to each other before disassembly, you should be ok.
Augustus Maximus: (2014-03-27 03:32:06)
After it came back from Midwest, notice dynamic seal
[archived image: DSCF4821.jpg]
Notice mark on turbine and compressor wheel
[archived image: DSCF4826.jpg]
Pretty eBay CHRA happily blowing up clutches and giving me traction issues
[archived image: DSCF4825.jpg]
Now I can use any dynamic seal rebuild kit.
Augustus Maximus: (2014-03-27 03:37:44)
Swapped the back plate and CHRA
[archived image: DSCF4823a.jpg]
So pretty
[archived image: DSCF4830.jpg]
One moar
[archived image: DSCF4829.jpg]
Goodbye.
