Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Oil catch can ? Best way
Imported from Z31Performance.com Forums{{#if:Coffeygr| — original post by Coffeygr}}{{#if:2018-02-09 10:05:32|, posted 2018-02-09 10:05:32}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/538590-oil-catch-can-best-way.html|
Coffeygr: (2018-02-09 10:05:32)
So Iâve read all 7 pages of the Pcv/catch can routing and discussion and i canât find a clear answer of how to route a catch can on our vgs
so i guess my real question is, is it better to get 2 catch cans (one for each side)- i donât mind cleaning/emptying 2 tanks
or a 4 -10an fitting catch can ( http://www.jegs.com/i/Vibrant-Perfor…SABEgJa_vD_BwE )
or would the Cusco oil catch tank on the zstore page work with out cars ( http://www.thezstore.com/page/TZS/PROD/10-2072 )
or do what careless did with his custom catch can
edizzle89: (2018-02-09 15:57:18)
I just T'd into the factory hose between the valve cover and the intake. That way it still flows just as Nissan intended it to just with a catch in the line.
Also I just used a water/air separator for air compressors as my catch can. They use a low micron copper filter which makes a great baffle and are only around $25. All you have to do is seal the fitting in the bottom of it.
Coffeygr: (2018-02-09 16:20:21)
Are you running a breather on the driver said valve cover ? Also it looks like your running -10an lines ? Thatâs looks pretty nice honestly lot simpler than i was expecting, and it works as intended?
edizzle89: (2018-02-09 18:17:31)
I think it's 5/8" hose, and I had a breather on the other side but my setup was tuned for just MAP and didnt have a MAF. Not sure if pulling air not metered by the MAF would cause any issue.
Coffeygr: (2018-02-10 11:00:05)
Iâll try a catch can on the passenger side and breather on other and see what happens with nistune
jy1235689: (2018-08-26 18:58:13)
Well, in each spot that a catch can would be, you can substitute a bmw oil separator (looks like a funnel with 2 tube inlets) and plumb the drain port to high on the oil pan.
no mess and no emptying.
