Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/O-ringing the vg30e block for…
Imported from Z31Performance.com Forums{{#if:yota73| — original post by yota73}}{{#if:2009-08-25 04:41:19|, posted 2009-08-25 04:41:19}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/8234-o-ringing-the-vg30e-block-for.html|
yota73: (2009-08-25 04:41:19)
Well I am looking through summitracing and noticed that the metal head gaskets require o-ringing the block. What exactly does this do and how much can it cost typically?
SATAN: (2009-08-25 04:50:23)
Puts a stainless steel ring around each cylinder bore that sticks up past the deck of the block. When you put the head on it creates a mechanical lock on the head gasket. When I had mine done, it cost me $230 to have the stainless rings installed. Looks like a wire around each bore.
I assume you are looking at copper gaskets since they require a ring?
Check z31parts.com to see what the status is with Jason and his steel head gaskets.
MachZ: (2009-08-25 04:53:28)
Last I checked they were in stock
DMANN: (2009-08-25 11:31:23)
Summit also sells ones that are copper but, do not require o-ring.
They require a gasket glue or something along that route!
Get Jason's gaskets!!!
yota73: (2009-08-25 16:38:34)
Well the head gaskets I was checking out were the summit racing ones and they state o-ringing the block is required. Thanks everyone for the help so far.
BenRR: (2009-08-26 01:59:26)
I ran these type of gaskets on my 3vzfe camry engine and problem always was with the coolant leaking under high boost hope you have better luck . I had a custom batch made by Cometic and that was bullet proof.
turbomike: (2009-08-27 02:00:27)
Everyone I know who uses copper seems to have coolant weeping / leakage sooner or later - they are designed for drag cars that get taken apart all the time… don't run copper unless you're OK with that. This is still true if you have the block O-ringed, as it leaks from the coolant ports.
Jason does have the MLS gaskets - I bought a set from him for my 3.3 build - they appear to be decent quality, I wouldn't say as nice as my old HKS MSL gaskets, but then again they are the best option we seem to have at this point.
SATAN: (2009-08-27 02:09:11)
Alright then, now we just need to have every hole on the block o-ringed then! I'm sure that will be cheap!
MachZ: (2009-08-27 02:20:45)
Ehh… just plug 'em. Who needs coolant and oil anyway? :nanan?re
