Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/New turbo ?
Imported from Z31Performance.com Forums{{#if:darryl rice| — original post by darryl rice}}{{#if:2014-09-04 02:37:33|, posted 2014-09-04 02:37:33}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24245-new-turbo.html|
darryl rice: (2014-09-04 02:37:33)
Has anyone heard about the new turbo from Precision Turbo; the 6870? Rumor has it making more power than the 7175 with a lot less lag.
turbofedz: (2014-09-04 03:45:52)
6262 or the 6766 should be plenty enuff.
amreboot: (2014-09-04 03:57:46)
It really depends on what you are wanting to do with the car.
Simple examples…
Autocross/drifting = 6262
High power/drag = 6766
Etc.etc
I run the 6765 billet dual ball bearing which was replaced with the 6766.
darryl rice: (2014-09-04 04:56:05)
It's an item to consider, I really would like to see if I can get 700-800rqhp out of my vg33 on high boost without blowing it up, once I assemble it. I did have my machinist do some modifications to crankshaft and block to asist with oil lubication. Just wondering if anyone heard anything
Racinjitter: (2014-09-05 02:36:42)
I'm running the PT6266. Good for 800whp. Supra guys are getting 824whp out of them all day long.
Racinjitter: (2014-09-05 02:38:18)
Also, the GEN2 wheels are outflowing larger turbos from previous generations of the same diameter by about 20%.
darryl rice: (2014-09-05 07:35:39)
{{#if:Racinjitter|Racinjitter wrote:|Quote:}}
What kind of numbers are you getting out your PT6266
