Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/My Turbo LS 5.3 build
Imported from Z31Performance.com Forums{{#if:BLITZERKING1| — original post by BLITZERKING1}}{{#if:2019-11-05 02:03:45|, posted 2019-11-05 02:03:45}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/544709-my-turbo-ls-5-3-build.html|
BLITZERKING1: (2019-11-05 02:03:45)
Posting this here in case anyone is interested. I'll be adding to the imgur album as I go. Car made 567whp on 93 octane pump gas
Basic Build specs:
5.3L LM7 out of a 2003 Tahoe, rings gapped
Summit Stage 2 turbo cam
PAC 1218 valve springs
241 heads off a Fbody
VS Racing billet 7875 Gen 1, 3" exhaust with Vibrant resonator
LS6 intake, Stock Truck TB
Z32 transmission with gforce adapter and flywheel
Z1 Motorsports Z32 TT performance 6 puck clutch
MS3 Goldbox with 24x harness
Snake eater 80lb Deka injectors
Walbro 450 fuel pump
EFI source 3bar MAP
Flipped truck manifolds into a hotside I made, Tial V44 wastegate
2.5" intercooler piping, 13"x24" intercooler, Greddy type RZ BOV
NGK TR6 spark plugs
Corvette accessory drive with ICT billet alternator bracket
Wilsonthesphere: (2019-11-06 15:58:59)
Nice build. how much boost were you running on the VG setup. Im curious because I was planning to run the S362 in the future but 480hp is short of my goals.
BLITZERKING1: (2019-11-19 23:55:21)
{{#if:Wilsonthesphere|Wilsonthesphere wrote:|Quote:}}
16psi
