Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Making power with stock turbo location
Imported from Z31Performance.com Forums{{#if:HarvesterUT| — original post by HarvesterUT}}{{#if:2014-11-04 15:07:43|, posted 2014-11-04 15:07:43}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24474-making-power-with-stock-turbo-location.html|
HarvesterUT: (2014-11-04 15:07:43)
My goal is to make 450-500 hp while keeping the a/c and most of the other fancy do-dads. What size turbo am I looking for, and will it fit in the stock location with intercooling pipes?
Thanks
ozzyrulez: (2014-11-04 15:16:03)
There are a lot of turbos that will fit in the stock location. HX35 will fit down there and it pretty big.
Axel kain: (2014-11-04 15:33:01)
My PTE 5857 fits down there nicely too. plus with the 2.5" V-band outlet, makes plumbing by the steering shaft super easy. just requires an external gate.
HarvesterUT: (2014-11-04 15:42:51)
Thanks for the info, guys.
One extra thing: I know that "max powah" desires come in all types of torque/hp curves. One set-up has a wide power band while another takes forever to get there but makes super top-end power. I'd prefer a set-up with a wide, smooth power band over one that requires you to goose it any time you want to really move.
1986zxt: (2014-11-04 16:50:51)
I kept the A/C with my setup. Had to use 2.25 plumbing
Axel kain: (2014-11-04 19:21:28)
I kept A/C on my customer's car.... ran 2.5" with a HX35 setup, and external gate on the manifold.
your goals depend on cams, cam timing, compression ratio, displacement, and turbo selection.
HarvesterUT: (2014-11-05 03:14:47)
I'll be doing a full build to include rods, pistons, cams, springs, valves, plenum & exhaust. I just want to ensure that my power goal won't be hampered by stock turbo location.
Axel kain: (2014-11-05 13:34:52)
with a bone stock engine.... your power goal would not be hampered by the stock location.
HarvesterUT: (2014-11-05 23:34:24)
Good to know. Gotta have that a/c down here in TX.
FlawleZ: (2014-11-05 23:35:52)
Lookup 1sickZ. 9 second Z31. Used stock manifold, stock location.
