Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Induction system volume
Imported from Z31Performance.com Forums{{#if:j30_vg33et| — original post by j30_vg33et}}{{#if:2006-06-29 06:33:09|, posted 2006-06-29 06:33:09}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/306-induction-system-volume.html|
j30_vg33et: (2006-06-29 06:33:09)
Here's something to think about': How much of an effect does the volume of the induction system really make? If you've got…
2.5" intercooler plumbing x 6' = 4.9in2 x 72in = 353 in3
3.5"x10"x16" intercooler core = 560in3 (10% charge air portion) + 2x3.5"x10" end tanks = 126in3
4L of intake plenum = 244 in3
Totals 723in3 = 0.418ft3
Now, if you're getting from 0-60 in under 4 seconds, you're making some pretty good power. Just for kicks, lets say 500hp. That's what, 650-700cfm? Since you're just using a fraction of that out of the hole, 200cfm, that still passes the volume of the intake system in…
0.418ft3 / (200ft3/min x min/60sec) = .125 seconds
Now reduce the plenum volume to 2L -> .347ft3 -> .104 seconds
So there's some crude calcs. Question for you guys out there with big manifolds: How much of a difference does it make at the pedal?
G-E: (2006-06-29 08:39:16)
one thing you didn't do was multiply by pressure… area x pressure.....
so any change in volume is magnified by boost, the higher the boost the more time it takes to fill/pressurize
