Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/IAC high boost pressure
Imported from Z31Performance.com Forums{{#if:Wilsonthesphere| — original post by Wilsonthesphere}}{{#if:2018-02-13 14:36:47|, posted 2018-02-13 14:36:47}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/538662-iac-high-boost-pressure.html|
Wilsonthesphere: (2018-02-13 14:36:47)
I have my IAC running into the valve cover and was wondering would is the IAC good enough to prevent higher boost 15-18 psi to leak out? Would it be better to run the IAC to the pressure side of my inter-cooler piping. I want to avoid putting a block off plate in its place.
Thanks
Timbo_021: (2018-02-14 09:39:46)
You got a picture of your setup?
