Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/HKS 3mm Copper head gaskets reused?
Imported from Z31Performance.com Forums{{#if:ralph50| — original post by ralph50}}{{#if:2015-04-30 13:24:15|, posted 2015-04-30 13:24:15}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24990-hks-3mm-copper-head-gaskets-reused.html|
ralph50: (2015-04-30 13:24:15)
How many times can the be reused?
I have some on my Z and have installed them twice.
They were not cheap and I would like to reuse them again.
88sinZ: (2015-04-30 16:38:58)
You can reuse them 2.7 times
300zxturboftw: (2015-04-30 19:43:17)
Ask yourself. Do you want to take apart the engine again due to a leaky head gasket? Replacing one is just peace of mind. If you do re-use it I would highly recommend letting a professional engine builder go thru the gasket to determine if it's reusable.
Spooledup300z: (2015-04-30 22:28:20)
My question is why are you removing and installing then 3x's?
ozzyrulez: (2015-05-01 04:53:46)
Sometimes I feel like I'm the only one still using OEM headgaskets
jaqattack02: (2015-05-01 12:09:55)
You're not. Unless you're going for lots of boost, the stock gaskets work fine.
ozzyrulez: (2015-05-01 13:34:33)
I've had the OEM gasket up to 26psi with no issues. That was with OEM head bolts too. I like to live dangerously lol
ralph50: (2015-05-01 13:38:58)
I have had said gasket for like 20 years.
It was super expensive back then.
I was just curious. From what I was told back then the gaskets were resuable.
This one has been used 2 times already.
