Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Engine break in.......................................
Imported from Z31Performance.com Forums{{#if:VG36ET| — original post by VG36ET}}{{#if:2007-01-30 04:55:54|, posted 2007-01-30 04:55:54}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/1567-engine-break-in.html|
VG36ET: (2007-01-30 04:55:54)
Whaddup ya'll,
I like this dudes write up allot. [archived image: biggrin.png] Even if you don't agree this is a great read. http://www.mototuneusa.com/break_in_secrets.htm Peace
utjon: (2007-01-30 06:28:24)
I couldn't resist getting on it in my titan when I first bought it. I didn't run it -hard- but yeah. The only thing that the manual specified was not to go over a certain rpm before 300miles, then another until 1000, or something along those lines. For the most part I stuck to it, but I'm not gonna lie… I did a few 6k runs on the engine during that time. Whatever works though!
OR-Zman: (2007-01-30 08:30:05)
Interesting, that is basically the feedback I got from the guy I had rebuild my heads and a local high performance engine builder.
Warm it up good, let it idle a bit high (1K) for about 10 minutes and then go drive it hard for about 15 minutes, but don't thrash it. Take it up to about 75% of red-line a few times for short periods as you are driving. Go home and then let it idle and cool out for about 10-15 minutes. After that try to stay below about 75-80% (5500rpm)of red-line for a thousand miles and after that let her rip. :wink:
I have to say, I worked like a champ for me. After over 3500 miles with some hard driving mixed in the engine still has that tight new engine sound. (you know what I mean if you have heard it before).
One other thing. Both guys told me to use the best natural oil I could get. They both suggested Chevron Delo 400. (worked for me since my old man had been using it since I was a kid in all his equipment) Run that for 500 miles. Drain it, and flush it with 2 quarts of the same to get the wear junk out as best you can. Then choose a synthetic and stick with it. Change it after 2k and then you should be good for 5K+ from there on. I have used Schaffers for years and they both agreed that it was better than most so I stuck with it. Both guys were also fans of Redline oils as well.
300zxt: (2007-01-30 08:42:42)
[archived image: MotoMan.jpg]
That guys not greasy enough, he cannot be trusted! lol jk
Firehawk: (2007-01-30 10:48:18)
Talk to enough people, and you will hear all kinds of ways to break in motors.
SATAN: (2007-01-31 02:45:01)
Yeah just build it and then drag it. Duh.
