Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Buying lifters question
Imported from Z31Performance.com Forums{{#if:BlazzinZ88| — original post by BlazzinZ88}}{{#if:2011-02-28 19:16:36|, posted 2011-02-28 19:16:36}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/13598-buying-lifters-question.html|
BlazzinZ88: (2011-02-28 19:16:36)
My engine has 8.5:1 bcr pistons .20 bore balanced with eagle rods ARP head & main studs OWO heads with ferrera valves isky mega cams and morgan cam gears.
I need new lifters to finish my build. Are parts store lifters ok or should I only use nissan oem ones? or are there any alternative ones I should use or try? Give websites if you know a good place. Courtesy was $233 for 12.
Also same question about flywheels. If I just want a stock flywheel are parts store ones good I dont have the money for an aluminum one.
Rick88ss: (2011-02-28 19:58:34)
chromoly flywheel from South bend clutch/DXD.
I would buy OEM lifters. I bought some Clevite lifters and they look to be reconditioned.
BlazzinZ88: (2011-02-28 21:21:51)
the SBC flywheel would be sweet but I don't think I can spend the $400 to buy since I am having to spend money on rust repair to my frame. I don't want to turn down my current flywheel since I did that once before allready. Don't really want to buy a used stock one to turn down cause I won't know if it was turned down or not before purchase. using it with a DXD stage 4 clutch. and 88NA 5 speed.
Russ84na: (2011-02-28 22:17:16)
http://www.mizpahprecision.com/pricing.htm
Used them in my 200+WHP NA build with not problems
BlazzinZ88: (2011-03-02 14:55:51)
wow thats a huge cost savings. is their any downside to using these rebuilt lifters vs new oem ones? the car will be red lining around 7.5-8k rpm with the cam and engine balancing that was done.
300zxturboftw: (2011-03-02 19:01:10)
As long as the lifters haven't been damaged or resurfaced before, they should work fine.
SATAN: (2011-03-02 20:31:18)
Resurfacing the lifter is fine as long as you keep the convex shape on the bottom of the lifter. The side that rides on the cam lobe.
300zxturboftw: (2011-03-03 05:07:18)
[quote]SATAN wrote:
Yea, maybe I was unclear. I meant if they were resurfaced previously. Could have too much wear to be unusable if you try to re-surface them again.
zmainiac: (2011-03-18 02:16:17)
I have used them a bunch of times with good results. Well worth the money but plan on shipping yours as they might not have litters in stock.
